Solid Axle Swap
Old Dec 21, 2014 | 01:36 PM
jmasselli22's Avatar
jmasselli22
Default Solid Axle Swap
I have a 2003 Dakota 4x4 4.7l. where can i find good solid axle. i want dana 44s. what size would fit my truck and where can i buy it?
Old Dec 21, 2014 | 07:39 PM
Tom A's Avatar
Tom A
Section Moderator
Grab both axles from a Jeep Wagoneer (or the whole vehicle). They'll be matching Dana 44s and already the correct width. There are some different ones through the years, so make sure you get a front with a driver's side diff and no axle disconnect (not sure if any of them even had that). There is also a wide track version that will work, but you'll need wheels with more offset if you don't want them to stick out.
Old Dec 21, 2014 | 08:13 PM
dipsherry's Avatar
dipsherry
i used a dana 44 hp from a 78 f250 and the rear from a 97 cummins
Old Dec 22, 2014 | 08:46 PM
dodgeramguy85's Avatar
dodgeramguy85
Full size axles will work but they are little large if you dont want your tires to stick out. Id go with wagoneer axles. Or could go bullet proof and get dana 60 front and dana 80 rear axle. They can handle the diesel so I think they can handle the dakotas power
Old Dec 22, 2014 | 10:12 PM
magnethead's Avatar
magnethead
or spend money on fab axles which can be made exact width...at a price. ^_^
Old Dec 23, 2014 | 09:52 PM
dodgeramguy85
If you have anyone in your area that is capable of doing it. Closest guy I know is 150 miles away
Old Dec 23, 2014 | 10:17 PM
magnethead's Avatar
magnethead
There's 2 race chassis shops and at least 1 off road shop that do in-house fabricated 9" axles here in DFW. Charlie Stewart Fabrication west of Fort Worth, TNT Supercars in Forney, and Baertrax Offroad in Dallas.
Can also take a factory axle, cut the tubes at a 45 degree angle, section out the needed amount, then weld back together and add gussets as desired. Would need a huge welder though, to penetrate the 3/8"+ thick axle tube. The outfit I've worked for in the past custom builds dana 80 front axles. VERY tedius, but very strong. They use a D80 rear center chunk, get 1/2" wall pipe lathed down on the end to the D80's tube diameter (the lip is about 1/8"), weld the tubes to the center housing (which is cast iron- takes LOTS of heat), and use custom machined knuckles and outers. The axle shafts use 1410 joints. Add gussets and it makes for a very strong, very costly front axle.
Old Dec 24, 2014 | 12:18 AM
jmasselli22
will the bolt pattern be an issue if i take one from the wagoneer? and do the wagoneers have danas?
Old Dec 24, 2014 | 12:29 AM
Tom A's Avatar
Tom A
Section Moderator
The bolt pattern on the Wagoneer axles is 6x5.5 (same as Chevy, Toyota) and does not match the Dakota. Better to use both Jeep axles.
Yes, they are Dana 44s.
Old Dec 29, 2014 | 06:12 AM
jmasselli22
is there anywhere else i can find dana 44s that will work on the dakota or is the wagoneer the only one. can i take them from a ram?
