Diagnosing a clunk
Old Dec 22, 2014 | 10:13 PM
JDak02's Avatar
JDak02
Default Diagnosing a clunk
Hey guys I'm new here, just recently bought a 2002 Dakota Sport 2wd with the 4.7..Got for a great price, can't complain, it's in real great shape, but I'd like to solve a clunking sound in the front end.
I only hear it when turning at low speeds if I hit a bump. It sounds like an obvious clunk..however when I turn into my driveway..it's a bit louder..and more of a clank. When changing the oil I glanced at the ball joints..boots are all intact, no signs of grease leaking out. I'm thinking sway bar bushings or end links. Just looking for pointers on what to check.
Thanks!
Some more info that might help, The clunk is there when turning left and right, and it's always the same sounds. That's why I'm thinking sway bar parts. Something could be loose causing it to move.
Old Dec 22, 2014 | 10:47 PM
magnethead's Avatar
magnethead
Does the truck jolt any when it happens? Crawl around under it, sway bar is easy enough to inspect. You can also jack up on control arm and see if it does it, or jack it up on the crossmember and see if it's a loose control arm.
Old Dec 22, 2014 | 11:21 PM
JDak02's Avatar
JDak02
I'll have to get back to you about if it jolts or not, I definitely haven't noticed any kind of tug or pull in the wheel when it happens. Pulling in the driveway all I hear is that pop/clank. Too slow to get a jolt I'm assuming. I'll pay closer attention tomorow and get back here about it. Mainly only if the front wheels are on uneven ground.
Old Dec 23, 2014 | 12:04 AM
01SilverCC's Avatar
01SilverCC
Bad sway bar end links. I have gone through several sets on my 2001. It had the same exact problem, kind of a loud metallic clunk sound when making left and right turns, and was worse when backing up and turning, like when backing out of my driveway into the street. Also had the problem to a lesser degree when going over speed breakers. New end links fixed it. My most recent set are the cheaper Master Ride parts from Napa and so far are holding up just fine. I don't know of any way to check the links other than checking the boots for rips and trying to feel for abnormal movement in the ball socket ends. When mine failed they had ripped boots, every time.
Jimmy
Old Dec 23, 2014 | 12:48 AM
Dodgevity's Avatar
Dodgevity
Jimmy
Agreed. I had the same clunking over rough surface. The end links on the sway bar were shot. The end that connects to the lower control arm had no rubber boots left on it. Replaced them with greaseable moogs and it feels nice and tight again.
Old Dec 23, 2014 | 01:48 AM
01SilverCC's Avatar
01SilverCC
I had greaseable end links before installing this most recent set of Master Ride parts. At my last oil change I saw that somehow one of the grease fittings fell out, and the link was stripped internally or some other strange problem because I could not thread a new fitting in no matter how hard I tried. I also tried the type of fitting you tap in with a hammer but I only succeeded in tapping my thumbnail with the hammer and giving myself a black thumb that hurt pretty bad for a few days. That was what led me to use the sealed Master Ride parts. So far so good with the new links.
Jimmy
Old Dec 23, 2014 | 11:41 PM
JDak02's Avatar
JDak02
Thanks for the replies! Everything described sounds like the issue I'm having. I'll get under it and check everything out tomorrow.
Old Dec 28, 2014 | 07:00 PM
JDak02's Avatar
JDak02
New front links and I'm clunk free!. Though the rears are shot, I ordered some Moog metal links for the rear, after discovering the oem replacements at Autozone are plastic..
