differential oil ?
Old Jan 1, 2015 | 10:18 PM
indiglofish61's Avatar
indiglofish61
Default differential oil ?
does anyone know if all the differential oil comes out of the differential when the cover is taken off in an oil change?
Old Jan 1, 2015 | 10:40 PM
All that matters, yes. No different than an engine oil change. There is always some residual oil that won't come out.
Old Jan 1, 2015 | 11:56 PM
tbugden's Avatar
tbugden
Yeah as jkeaton said, pretty much all comes out. I would try to get out as much as possible, not because I think the few ounces of leftover fluid are going to make any difference at all, but just to check thoroughly for any debris/metal shavings (small amount of metal "dust" is common and normal).
Also check and make sure your axle vent is not clogged just as a precaution. If it's the same as the 1st gens the vent is screwed into the driver's side axle tube and serves a dual duty of keeping the brake distribution block on.
Old Jan 2, 2015 | 09:35 AM
indiglofish61
is that axle vent inside where the differential is? on the drivers side?
Old Jan 2, 2015 | 09:44 AM
Dodgevity's Avatar
Dodgevity
Yeah, pretty much. Think of a bell laying on it's side and thats the diff. You can stick a rag in there to soak up any residual laying at the bottom, if you wish. I sprayed it all over with brake cleaner and let it dry out. There is a magnet sitting at the bottom that you should clean. Here is a pic of mine before I cleaned it.
Old Jan 2, 2015 | 09:48 AM
It is on the differential housing. A vent with a tube that should run up to the frame rail.
