Yet another exciting rear diff thread
I can confirm, and I think that now dodgevity can confirm as well (assuming he watched what I PM'd him), that the tires are almost meaningless when put around a nose-heavy/tail-light truck with any kind of traction device. I have brand new destination AT's on all 4 corners and I can whip it around like nothing....
That's crazy, Magnet. I'll set my carrier aside just in case I don't like the results. So what is the most preferred locker or LSD setup out there... one which behaves like an open diff during normal and kicks in only when you actually need it, rather than interfering with your driving?
Are the carriers in a Dodge 4x4's rear diff the same as 2WD models with anti-slip?
Which Jeeps are you talking about?
I think he means the cherokee's. They also use the 8.25 (smaller) axle as some dakotas. Other dakotas, durangos, and some ram 1500's use the 9.25 .
The best of both worlds is an ARB air locker, until you see the price tag.
*takes sunglassess off*
Inflated?
(Please toss the rotten produce over into the compost pile, kthx)
RwP
With the ARB air locker, you have to install an air compressor? Wow
Thanks, dude. Looks like you were having some fun there. Although, If I threw my Dak around like that, I imagine it would do the same thing with this open diff on wet road. Like you said... nose heavy and tail light + wet road... stomp on the gas and it will break loose. I'm sure the dynamics are way different with a locker though. Guess I need to get out there and drive one.
There are electric lockers out there that work on the same principle, but i'm told the electromagnets don't tend to last long.
Okay, so in my quest to find a junkyard LSD (or locker), I want to be sure that I'm in the right ballpark. So basically, any Chrysler product with 12 bolts on the diff cover should be a 9.25 and I can check the tag (if there is one) for LSD? Are there any other identifiers which would clue me in aside from vehicle markings... 4x4, etc?
(from another thread)
Thanks for all the help. I don't know how this will all turn out. Maybe I'll get lucky, pull a diff cover and see an air locker inside, in the junkyard. LOL
