Lifting power window without power
Old Mar 10, 2015 | 03:22 AM
redtalmage's Avatar
redtalmage
Default Lifting power window without power
Need to 'rollup' driver electric window manually. Went down, now no up. Have correct voltage at 'motor' connector.
Old Mar 10, 2015 | 04:40 AM
redtalmage's Avatar
redtalmage
Default Fixed it (temporarily)
Cleaned switch contacts.
Cleaned & tightened main connector. Did same w/motor connector. Still no joy.
When all else fails - get a bigger hammer.
Multable hammering on motor while toggling up switch finally got glass to rise from dead.
Old Mar 10, 2015 | 01:36 PM
archemedes74's Avatar
archemedes74
was going to say if you unbolt the motor usually (most vehicles I've worked on anyway) have a place needlenose pliers fit and you can manually roll it up
