ac clutch not engaging
Old Apr 1, 2015 | 08:07 AM
grilla3's Avatar
grilla3
Default ac clutch not engaging
I have 03 dakota 3.9.ac clutch is not engaging I have power on both leads going into comp.when motor is running 14.4.with ac on,with ac off only black wire has volts..If i run jumper to black whitewire side of compressor coil it comes out on black wire hot.changed coil still same.it was a used coil but before i changed it i ran hot to one side grounded other and magnate worked.now it don't.does that mean coil has shorted out.any help would be apreiciated tks in advance
Old Apr 1, 2015 | 09:00 AM
Is the system charged with the correct amount of refrigerant?
Old Apr 1, 2015 | 10:19 AM
grilla3's Avatar
grilla3
i think so don't have gauge.has pressure if im getting power to coil shouldn't it kick onI tried to add 134 but it wouldn't take it in I checked hi lo switch it has 3 wires 2 have 5.3 volts one has nothing tried to jump it but it cut motor off
Old Apr 1, 2015 | 10:55 AM
grilla3's Avatar
grilla3
im going to get a set of gauges now
Old Apr 1, 2015 | 11:16 AM
Jump the pressure switch. If the compressor comes on, it's low on refrigerant.
Old Apr 1, 2015 | 11:18 AM
grilla3's Avatar
grilla3
how do u jump pressure switch plug has 3 pins.what is correct hi an lo pressure
Old Apr 1, 2015 | 11:30 AM
Pressure switch should have just two. It's on the refrigerant pipes usually close to the drier. Pull it off and put a paper clip across the sockets on the plug.
Old Apr 1, 2015 | 12:55 PM
grilla3's Avatar
grilla3
this one has hi and low together i think .its the only switch in ac line its next to high pressure outlet.it screws into line
Old Apr 1, 2015 | 01:12 PM
Yeah, just remove the connector. No need to take the switch out of the line. It is a two connector switch on the low pressure line.
Old Apr 1, 2015 | 02:20 PM
grilla3's Avatar
grilla3
tried that didn't work put a set of gauges on it blue side read 85 red side read 110
