Brief engine rattle at start up
Old Jul 8, 2015 | 02:24 PM
Dodgevity's Avatar
Dodgevity
Default Brief engine rattle at start up
With 260K, you guys might tell me to just shut up, but I get a brief clatter at cold startup, until the oil pump does it's thing. Lasts about five to ten seconds... been this way since I got the truck. It was one of the reasons why I considered running a motor flush through it.
Lifters?
Old Jul 8, 2015 | 02:57 PM
98DAKAZ's Avatar
98DAKAZ
I've run two engine flushes through my 2.5 with good results but your engine is dramatically different than my simple old school 2.5.
I don't think its anything more than old age lifters not as responsive as they used to be and your oil pressure may be a little low at 260K on startup.
New lifters may help at 260K but its no simple task to replace them.
Old Jul 8, 2015 | 03:49 PM
jondakotaguy's Avatar
jondakotaguy
My 5.2L does the same thing but only about 1-2 seconds.. esp if it sits a while with out being ran. But I threw after i did my timing change and intake plen. fix the high mileage type oil in there which is a synthetic blend and it has not done it since i started use it.. just a thought..
BUt most say the same thing it is what it is until oil gets to the upper end. I'd run some synthetic through there see if it does not help quite it down and keep it a little extra lubrication if your not already using it.
Old Jul 8, 2015 | 05:18 PM
Dodgevity's Avatar
Dodgevity
I've been running full syn PP for the past 3 oil changes. Oil pressure gauge is always dead center. I wasn't planning on tearing into it as I think it might be normal at this age. Was considering the flush in case the oil ports are not operating full bore. As always, I fear sludging the sump tho. Jon are u running valvoline maxlife?
Old Jul 8, 2015 | 11:42 PM
RalphP's Avatar
RalphP
One more thing, somewhat tangentally related:
Ford's modular motors are bad about follower noise on a cold start until the oil starts to circulate. Also, my 1988 3.9 with a cheap filter rattles like it's going to toss all its rods out the side for the first few seconds. OTOH, now that I'm using Wix and Motorcraft filters, I don't have that - they seem to have the best anti-drain-back valves of the brands that fit both cars.
May be worth changing the brand of oil filter to one with a much better ADBV - there's reviews all over the Internet where they cut the various brands apart and compare them.
Shucks, my favorite site for lubrication information ( BobIsTheOilGuy.COM ) has a forum where they post the tear-aparts for comparision.
RwP
Old Jul 9, 2015 | 08:39 AM
Dodgevity's Avatar
Dodgevity
I spend time on BITOG too.
Currently running Bosch Distanceplus filters in my cars. The rattle that I get is pretty muted and not noticed by anyone but me. As mentioned earlier, it's most prevalent if the truck sits for a few days. Maybe all these trucks have it. I'm just super sensitive to everything that goes on with my vehicles. Always have been.
Old Jul 9, 2015 | 01:10 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
You could always drive it up to Nashville and sell it to me at a heavily discounted price !
Old Jul 10, 2015 | 09:13 AM
Dodgevity's Avatar
Dodgevity
Yessir! I'll treat you to lunch and free drinks while we close the deal and you can drop me off on side of the highway for the long walk back home.
Old Jul 10, 2015 | 02:31 PM
Robertwav1's Avatar
Robertwav1
I have always had that rattle as well, even when warm. It goes away.
Old Jul 10, 2015 | 05:53 PM
jondakotaguy
Yes sir i am..
get you a mech. stethoscope have someone start the truck and hunt the main valve covers timing covers and such thats how i found mine was noisey...
I'm thnking about those two OHC chains.. possible they are not getting lubircation enough at first or something is a miss in there.. loose streatched?
My 5.2L had a rattle like that once i replaced my timing chain it was good.. yours is gonna have those long pain in the *** one's... lots of places to 'rattle' on .. if its not a lifter but those should quiet up really quick once oil squirts out like a male virgin and his first .... you get the idea. LOL
