Lifting without a lft kit
Old Aug 17, 2015 | 12:30 PM
Paul Zsigrai's Avatar
Paul Zsigrai
Default Lifting without a lft kit
Have a 1997 Dakota Sport 4x4. What springs would you recommend to raise the front and what about the rear end as well?
Old Aug 17, 2015 | 12:43 PM
What vehicle?
Old Aug 17, 2015 | 05:38 PM
Paul Zsigrai
Old Aug 19, 2015 | 05:07 PM
jondakotaguy's Avatar
jondakotaguy
the 4x4 has torsion bars; not springs..
You can crack the torsions to get a little more lift in the front more of a level unless you put blocks in teh back but with out a kit thats all your gonna get.
Old Aug 19, 2015 | 06:16 PM
^^ this.
Old Aug 20, 2015 | 08:36 PM
dodgeramguy85's Avatar
dodgeramguy85
Cranking the torsion bars is the only way to get some lift. Depends how much you are looking for.. Cranking the front will bring it about level with the rear
Old Aug 20, 2015 | 09:52 PM
magnethead's Avatar
magnethead
also also make it ride much firmer, and depending on how far you go, may no longer be able to get within camber specs.
Old Aug 20, 2015 | 10:34 PM
dodgeramguy85
Ride in an older 3/4 or 1 ton truck and you won't notice a difference in the Dakota. At 1.5in of lift it isn't much to get it back in specs.
Old Aug 20, 2015 | 10:36 PM
magnethead's Avatar
magnethead
well yea. I'd call that about analogous. But a stock dakota and a dakota with 1.5-2.0 cranked in the bars are night and day...former is a car, latter is a 3/4-4/4-5/4 ton truck.
Old Aug 20, 2015 | 11:05 PM
jondakotaguy
When I cranked mine didn't notice a bit of difference in the quality of ride..
