power streering pump
Any happen to know the diameter of the pump shaft on the 2001 4.7L quad cab 4x4 dakota? cause i think the pump on my truck is going bad. Granted i cant tell if its the pump or the Pressure line. But i figured i would ask to find out cause according to rock auto there is a 17 mm or a 18 mm. i will be changing the pressure line first to see and hoping thats it.
I wouldn't worry about that get a pump with the pulley wheel already attached as removal and installation of the pulley is a PITA avoid that at all cost.
Sounds easy its NOT
Sounds easy its NOT
