2003 Dakota wont move unless in 4H
Old Oct 13, 2015 | 09:18 PM
jrlaplante's Avatar
jrlaplante
Default 2003 Dakota wont move unless in 4H
Wife was driving and said she heard some clicking noise. Shortly after the truck lost forward power and she pulled over. Engine runs fine but truck will not move in any gear. If you change selector from AWD to 4H the truck will drive. I'm thinking front transfer case but not sure. Any ideas?
Old Oct 14, 2015 | 12:15 AM
magnethead's Avatar
magnethead
Sounds to me like like the differential in the transfercase may have come apart. Front differential is also possible, though.
Old Oct 14, 2015 | 08:21 PM
00DakDan's Avatar
00DakDan
Section Moderator
Could also be a bad ring/pinion in the rear differential.
Is the rear driveshaft still in place?
Pull the cover and check the gears. I don't think the front differential is bad, I think it's the only reason you're moving now. When you put the t-case into 4WD it locks the front/rear driveshafts together.
Old Oct 14, 2015 | 09:57 PM
magnethead's Avatar
magnethead
by the same token, if the front was shot, the differential in the T-case would send all drive to the less-resistive front. So it could technically go both ways.
Easy way to tell? Put it in AWD and have a friend put it in drive while you watch the rear driveshaft to see if it turns. You might be able to see the front driveshaft (I don't have a 4WD so I don't know how far down it goes). Whichever one turns and the vehicle doesn't move is the one that's shot.
Old Oct 15, 2015 | 08:31 PM
00DakDan's Avatar
00DakDan
Section Moderator
Good point.
Old Oct 17, 2015 | 01:04 PM
jrlaplante's Avatar
jrlaplante
Default Update
OK, I pulled drive shaft and towed home. With drive shaft removed the truck will not move either in AWD or FWD. makes the grinding noise which is coming from the front transfer case.
Old Oct 18, 2015 | 02:19 PM
magnethead's Avatar
magnethead
which driveshaft? The front or rear?
There's only one transfercase in the middle of the truck. Are you saying the front axle is making noise when towing?
Old Oct 18, 2015 | 09:53 PM
jrlaplante's Avatar
jrlaplante
Rear drive shaft. Now will not move and noise is coming from underneath drivers side when truck is put into drive.
