Hub Assy Check
Old Oct 15, 2015 | 11:32 PM
98DAKAZ's Avatar
98DAKAZ
Forced the new pads on wow that's rich?
Old Oct 16, 2015 | 08:52 AM
Dodgevity's Avatar
Dodgevity
Originally Posted by dodgedartmike
I did not have the piston compressed far enough into the caliper and forced the new brake pads on the rotor which caused the overheating.
I still don't see why they would have overheated as once you started driving, the caliper would have adjusted to the width, unless by forcing you leaned the piston and got it stuck.
Old Oct 18, 2015 | 04:16 PM
dodgedartmike's Avatar
dodgedartmike
Default Hub Assy
Well, the problem was not solved. The next day the brake rotor overheated on the passenger side. Removed wheel and inspected rotor and caliper and did not see a problem. Since the rotor had been overheated I took to O'Reillys to make sure the rotor had not warped. Needed to be turned to purchased re-mfg caliper and new brake hose. Installed and flushed/bleed brakes as suggested and "now" it appears that the problem is solved. I'll let you know if there are more problems. Thanks again for all your input!
