Noise when changing HVAC mode
Old Nov 13, 2015 | 08:52 AM
Dodgevity's Avatar
Dodgevity
Default Noise when changing HVAC mode
When I switch airflow modes to to either of the defrost settings (mostly when I go from recirc, clockwise to full defrost), I get an angry chipmunk sound that lasts about two seconds. Sounds like I need some lube in the mechanism. Was wondering if any of you experience this, and if you've been able to solve it, short of dash disassembly? It's nothing highly noticeable but I'd rather lube it before it breaks. I'm hoping some spray lube with a long straw may work, as long as I can find the spot.
Thanks
Old Nov 13, 2015 | 09:03 AM
98DAKAZ's Avatar
98DAKAZ
Look under the dash and extract the rodent everything will be ok!
Problem solved you are welcome
Old Nov 13, 2015 | 09:06 AM
00DakDan's Avatar
00DakDan
Section Moderator
It's likely coming from one of the actuators - they're electric in your '03. You won't be able to lube them short of taking them out and disassembling them.
Old Nov 13, 2015 | 09:10 AM
98DAKAZ's Avatar
98DAKAZ
Call (1-800 extract rodents) if you cant find the little fuzzy bugger.
Old Nov 13, 2015 | 09:52 AM
Dodgevity's Avatar
Dodgevity
Originally Posted by 98DAKAZ
Look under the dash and extract the rodent everything will be ok! Problem solved you are welcome
I see you're having fun today.
Hmm... any of you guys getting this?
Old Nov 13, 2015 | 12:06 PM
00DakDan's Avatar
00DakDan
Section Moderator
OK, I'm confused.
Getting what? You'd have to remove the actuator and then take it apart to even have a chance at lubing it.
Live with the noise.
Old Nov 13, 2015 | 12:34 PM
Dodgevity's Avatar
Dodgevity
OK, I'm confused.
Sorry, Dan. I was asking if any of you guys are getting that sound. That's what happens when I type too fast at work.
Old Nov 13, 2015 | 02:45 PM
00DakDan's Avatar
00DakDan
Section Moderator
No problem.
More than likely there is a gear that is worn/stripped in the actuator itself.
Old Nov 14, 2015 | 03:40 AM
98DAKAZ's Avatar
98DAKAZ
Has anyone tried to replace these servos at all you never know it may be easier than on say 2001 and older dakota like my Dak thats vacuum operated? Look in the service manual you may not need to remove the dash like on the older Dakotas just tilt it out still work but maybe not as bad.
I guess the rodent extraction didn't work!!
rockauto only shows one servo available
Old Nov 14, 2015 | 11:34 AM
98DAKAZ's Avatar
98DAKAZ
This may help you service manual shows you must remove the dash but try to pull the glove box you may get access to one of the servos if its the bad one I cant say.
x
x
