Replacing rear axle assembly. What can/can't I do?
Bought a 2002 quad cab 4x4. Pinion nut came lose, pinion went back into differential, need ne assembly or fully rebuild.
It's hex cover, 9.25 ring, 3.92, 11" brakes.
What else can I use? Same ratio of course as I don't want to change front diff. That combo is really hard to find tho and when I do, VERY expensive compared to the other combos.
What would be wrong with the round cover smaller ring? Or if same cover and ring, the smaller brakes and then just swap out backing plates?
Feel free to email as well. Really need to find something I can afford quickly and get this back on the road.
Thanks!!!
Thanks!!!
