Oil Pressor Issue
Old Nov 29, 2015 | 06:52 PM
Dodgevity's Avatar
Dodgevity
Oil pressure sender issue...
https://dodgeforum.com/forum/2nd-gen...sure-drop.html
Heater core flush...
https://dodgeforum.com/forum/2nd-gen...ore-flush.html
Enjoy....
Old Nov 29, 2015 | 06:57 PM
RalphP's Avatar
RalphP
Again, I'd spend the money on a good scanner - such as the generic ELM327 Bluetooth adapter I mentioned, which can be had for as low as $3.27 on Ebay (note: not saying those are good ones, but that they're darn cheap nowadays) and Torque for an Android phone or tablet with Bluetooth capability can be had for free (Torque Free is the name).
For that kind of money, NOT having a OBDII scanner that can read the data streams is pretty darn not-smart, IMO.
RwP
Old Nov 29, 2015 | 08:04 PM
meece0927's Avatar
meece0927
It just blew up lost all power and then shut itself off
Old Nov 29, 2015 | 09:30 PM
00DakDan's Avatar
00DakDan
Section Moderator
What do you mean "blew up?"
Old Nov 29, 2015 | 09:38 PM
meece0927's Avatar
meece0927
Lost all power wouldn't go over 30 MPH I was right at my house so I coasted into the driveway horrible noise from the motor then it shut itself off.
Old Nov 29, 2015 | 09:40 PM
meece0927's Avatar
meece0927
I got it to start back but it struggled really really bad and took a little bit to start. Now that it is at the house idk wat to do replace the motor or fix wat ever the hell is wrong with the one that is in it.
Old Nov 29, 2015 | 11:41 PM
RalphP's Avatar
RalphP
I'd say "Yes".
Ideally, find a good core in the boneyard, and rebuild it then drop it in. Edit: If you have the 3.9, may want to look for a 5.2/5.9 from a 1998, and pull the ECU and the extra two injector wires also. Be a good time to beef it on up! EndEdit
Secondly, pull yours, rebuild it, and drop it back in.
Both presume you have another daily driver you can use during the rebuild time.
While rebuilding, check out the various Mopar forums (not just the Dakota ones!), grab a couple of the better Mopar LA/Magnum rebuilding books, and pour over them.
(The Magnum block you have is a derivative of the LA block, and as long as you brace for the differences, a lot of the steps are the same between them - and as long as you stick with the Magnum variants for when they're different, a lot of the parts are comparable / interchangeable.)
Sounds like you did lose oil pressure, not a gauge failure, in that motor. Not being there I have NO idea what you did or didn't do to cause it with the intake manifold job. And it's possible that it's coincidental. "Commonality does not always imply causality". Sometimes B breaks when you work on A, but A would have broken anyway!
RwP
Last edited by RalphP; Nov 29, 2015 at 11:43 PM. Reason: Had to go back and look what motor and year this was
Old Dec 7, 2015 | 03:12 PM
meece0927's Avatar
meece0927
Well from wat I have seen with wat little I have tore into the Motor isnt actually that bad. Spun a Rod Bearing. Gonna change the Rod and Main Bearings, Main Bearing Housing, get the crank refaced and balanced and should be good. Other than changing the Oil Pump and the Oil Pickup tube.
Old Dec 7, 2015 | 06:13 PM
RalphP's Avatar
RalphP
While the motor's apart, do the timing chain/gear set. And I'd suggest considering adding the tensioner to replace the cam retainer.
RwP
Old Dec 29, 2015 | 09:40 PM
meece0927's Avatar
meece0927
Well I got the motor out and everything and have finally seen the worst Pick Up in my life like for real WTF.
File Type: jpg
