03 4.7 transmission overdrive issue
Old Jan 4, 2016 | 07:50 AM
standardsta's Avatar
standardsta
Default 03 4.7 transmission overdrive issue
I have a 2003 Dakota 4.7 4 door 4x4. Recently I noticed Overdrive was lacking in power and had poor fuel economy. If i turn OD off my gas mileage increases significantly and the truck has much better throttle response (obviously the throttle response is due to a lower gear) the transmission shifts fine otherwise. Only other issue i have found is on cold startup it takes a few revs to engage in reverse. The fluid is full and clean. No burning or discoloration. No codes, speedo and cruise work properly.
Old Jan 4, 2016 | 08:04 AM
Never heard of overdrive causing poor fuel economy. How are you determining this?
Old Jan 4, 2016 | 08:32 AM
00DakDan's Avatar
00DakDan
Section Moderator
Not sure about the fuel economy part either. If it is taking "a few revs" to go into reverse you could have a problem with the solenoids, slipping clutches, or low line pressures.
Time to start looking at it before it gets MORE expensive.
Old Jan 4, 2016 | 10:05 AM
standardsta
I am also very surprised about the fuel economy. The HUD avg mpg, as well as monitering my fuel use determined this. The cold start issue with engagement may just be a check valve problem.
Old Jan 4, 2016 | 12:24 PM
Dodgevity's Avatar
Dodgevity
What about the two filters....have you replaced those lately?
