No Power When Gas Given
Old Jan 31, 2016 | 09:28 AM
IceNine's Avatar
IceNine
Default No Power When Gas Given
Recently I picked up a 98 Dakota R/T. Was told it didn't run when purchased. We did get it running but whenever we gave it gas it didn't like to go up in rpms at all. It gave some error codes. We finally figured out that the distributor was by about 180 degrees. We fixed that. Now we have no error codes/check engine light but the truck is still doing the same thing. It does idle better now though. But as soon as the gas is given it wants to stall out.
Kind of at a loss at what would be causing the problem now.
Old Jan 31, 2016 | 10:22 AM
What engine? How many miles? If it's a 318 or 360 have you checked the plenum? Clogged cat could cause it due to a blown plenum.
Old Jan 31, 2016 | 04:27 PM
IceNine's Avatar
IceNine
It's the 5.9l and 130,000 miles. The cat and exhaust are removed currently.
Old Jan 31, 2016 | 05:20 PM
So what else have you done and/or changed so far so that we don't sit here a and suggest things you have already done.
Old Jan 31, 2016 | 06:04 PM
IceNine's Avatar
IceNine
Changed the distributor cap and rotor, took the exhaust off, reset the distributor, unplugged and replugged all major sensors. That should be it.
Old Jan 31, 2016 | 06:23 PM
WrenchMasters's Avatar
WrenchMasters
Have you checked for any vacuum leaks?
Old Jan 31, 2016 | 06:51 PM
What about plugs and wires?
Old Jan 31, 2016 | 07:15 PM
IceNine's Avatar
IceNine
Plugs and wires are good. There are no vacuum leaks.
Old Feb 13, 2016 | 08:20 PM
theJester517's Avatar
theJester517
I was gonna say O2 sensors but I guess that doesn't apply when the exhaust is removed....
Old Feb 14, 2016 | 12:20 PM
44dakota's Avatar
44dakota
did you set the fuel sync?
