gear shifter
Old Feb 4, 2016 | 09:24 AM
jerseyboy69's Avatar
jerseyboy69
Default gear shifter
gear shifter on 2001 dodge dakota . a little tough getting out of park when u first start it. fine while driving until u stop and turn off and start again. 3.9 v6 automatic
Old Feb 4, 2016 | 01:49 PM
bwburleigh's Avatar
bwburleigh
I have same problem on 2002 V-8. It seems to only happen when cold starting. After initial use works fine all day. Do you know what is causing it ?
Old Feb 5, 2016 | 10:44 AM
jerseyboy69
Old Feb 5, 2016 | 10:46 AM
jerseyboy69
mine was giving me a problem when starting . did like guy said in video took rubber houseing offf ignition and sprayed some wd-40 been fine so far no problem
Old Feb 10, 2016 | 11:30 AM
bwburleigh's Avatar
bwburleigh
jerseyboy69,
Thank you for your input. Followed the u-tube feed and everything was just as shown. I lubed the mechanisim and everything is good. Next day the temp was 15 and it came out of park smoothly. Thanks again.
Old Feb 11, 2016 | 10:00 AM
jerseyboy69
happy to be of assistance bwburleigh
