Signal problem
Old Feb 25, 2016 | 05:14 PM
BigGreenRam's Avatar
BigGreenRam
Default Signal problem
2000 dakota all signals work just fine ...... but when the 4ways on right front does not flash just need to confirm that it would be the combination switch is bad thanks for any and all help had to jump over here from the 2nd gen dodge forums
Old Feb 25, 2016 | 09:24 PM
00DakDan's Avatar
00DakDan
Section Moderator
Multifunction switch.
Yes, most likely looking at the schematic. It shows that the multifunction switch ties both the L-R rear turn signals together when the hazard feature is depressed but uses a separate contact for each of the front turn signals. One must have failed.
Old Feb 26, 2016 | 06:57 AM
BigGreenRam
Thanks 00dakdan yeah it's all ways the high priced fix lol have a great day
