Random misfire. Can't find it
Old Mar 19, 2016 | 03:16 PM
madclicker's Avatar
madclicker
I am wondering why yours is always same cylinders?
Old Mar 19, 2016 | 06:47 PM
Robertwav1's Avatar
Robertwav1
I am wondering the same thing. I just did some resoldering on one of the PCM's I have and trying that out now. It may take 3 or 4 days to tell as it does not always do it. I suspect the PCM cause apparently you can't buy new ones anymore, only rebuilt. I'm wondering how good a job they actually do? The junk yards around by me anyway have NONE. From watching videos on the PCM apparently the Dakota and Durango have known issues. One is a faulty IAC driver, intermittent and another is an EPROM causing communication failure and another is a 12 to 24 volt step up transformer. Still studying, still looking and I guess it will eventually get figured out. One of the hardest things I've had to deal with in reference to electronics. What a nightmare!
Old Mar 19, 2016 | 07:40 PM
madclicker's Avatar
madclicker
If you google about the misfires ,it is fairly common,i am going to go with my gut and change my distributor was reading about this problem and hall effect inside the dist gets carboned up,will let you know tomorrow if it worked
Old Mar 20, 2016 | 12:18 AM
Burned's Avatar
Burned
I know on the Chevy engines a worn distributor gear was quite common and caused misfires. Pull the distributor and check the gear?
Old Mar 20, 2016 | 06:42 AM
98DAKAZ's Avatar
98DAKAZ
Stop don't do that you will possibly offset the fuel sync not a good thing.
Old Mar 20, 2016 | 10:38 AM
Robertwav1's Avatar
Robertwav1
Yeah, I don't know about pulling the distributor when it can easily be checked for play or slop by observing the rotor and have someone turn the crank pulley. I fail to see enough wiggle in mine to cause a problem. Not saying it can't be the problem.
Old Mar 20, 2016 | 11:07 AM
madclicker's Avatar
madclicker
Great points ,i am going to just change the pickup,assuming i can without pulling dist. Thanks everyone! And on a side note this forom is the best 2 others could not help or come up with a answer that made sense
Old Mar 20, 2016 | 11:58 AM
Dodgevity's Avatar
Dodgevity
Are you losing any coolant?
Old Mar 20, 2016 | 12:05 PM
madclicker's Avatar
madclicker
Nope not at all,very frustrating to say the least!
Old Mar 21, 2016 | 09:40 AM
Burned's Avatar
Burned
Putting the engine at TDC or marking the distributor in relation to the engine block before pulling the distributor so the cam sensor is aligned with the cam is going to cause a problem?
Sorry I am new here. Thought its was pretty much like any other engine that uses a cam sensor in the distributor for injector timing.
