EVAP Big leak detected code P0455
Old Apr 2, 2016 | 10:10 AM
hhaywoodjr's Avatar
hhaywoodjr
Default EVAP Big leak detected code P0455
My check engine light is on and I get this code when I check codes on my 2002 Dakota 4.7. I've checked all of the connections and everything looks ok. Is there a fuse for the evap purge pump and if so what is it.
Old Apr 9, 2016 | 08:06 PM
madclicker's Avatar
madclicker
Hi, crawl under your truck and you will see a big box right around the doors there are 2 rubber hoses that are cracked or even dryrotted and fell off get new evap hoses and change them dakotas are known for this
Old Apr 11, 2016 | 01:33 PM
00DakDan's Avatar
00DakDan
Section Moderator
I moved your thread to the technical forum.
Definitely check all the hoses. It could also be a rotted fuel filler neck. A gas cap is less likely but it can happen.
