Misfire
Old Apr 20, 2016 | 06:17 PM
dodgedakotaslt's Avatar
dodgedakotaslt
Default Misfire
Hey guys i need some advice on this. I had a p0308 code last week so i changed all the spark plugs and now i just got the same code back. Wat are some of the thing that could cause the misfire again. I replaced the ignition coils back in march of 2014.
Old Apr 20, 2016 | 07:22 PM
00DakDan's Avatar
00DakDan
Section Moderator
P0308 misfire cylinder #8.
Swap the coil with another cylinder and see if the problem follows.
Check the plug while you're at it.
What plugs are you running?
Old Apr 21, 2016 | 03:33 PM
dodgedakotaslt
I used the champion spark plugs
Old Apr 21, 2016 | 04:34 PM
00DakDan's Avatar
00DakDan
Section Moderator
Good. Sometimes the coils burn out if you use anything but the copper OEM plugs.
Old Apr 22, 2016 | 07:05 PM
dodgedakotaslt
it was the coil pack that was bad I just wasn't excepting that to be the reason since all the coils were replaced at the same time
