2002 Dodge Dokota V6 loosing power, diagnosis? help?
Old Apr 24, 2016 | 09:29 PM
paulsheer's Avatar
paulsheer
Default 2002 Dodge Dokota V6 loosing power, diagnosis? help?
Hello,
My 3.9L V6 is loosing power intermittently.
I tested the vacuum and fuel pressure. 20psi and 45psi respectively. Both stable at idle. I pressed the purge button on the fuel pressure tester and the pressure quickly restored to 45psi. So vacuum and fuel pressure look good, no?
I also just noticed the CEL -- although I don't know when it came on.
Below is the OBDII code, and the OBDII live readings from my budget code reader.
The throttle is also behaving weirdly -- seems to have an unsmooth map between how hard I press and how much power I get. TPS do you think?
Does anyone have any ideas?
Thanks!
Paul
Old Apr 25, 2016 | 09:00 PM
paulsheer's Avatar
paulsheer
bump.
Old Apr 28, 2016 | 11:06 PM
paulsheer's Avatar
paulsheer
Bump, and update --
I changed the O2 sensor with a new Denso. I also changed the TPS.
Old Jun 1, 2016 | 05:49 PM
paulsheer's Avatar
paulsheer
didn't realize i'd be overwhelmed with so many responses
well i changed the throttle position sense, the oxygen sensor, and the trans lever position sensor -- which was leaking transmission fluid
it's been a few weeks now and the problem has not recurred.
Old Jun 1, 2016 | 06:28 PM
diverherb's Avatar
diverherb
I am not on her often and just saw this. From the looks of your short term and long term fuel trim I would suspect the O2 as the culprit. I have also seen leaks on the exhaust side cause the O2 to act up and give bad readings.
