No Bus
Old May 29, 2016 | 09:06 AM
David Dudemaine's Avatar
David Dudemaine
Thanks Dan and Friar. So I'm having a hard time trying to buy the replacement part. So far, this is the only thing I found. The weather has been bad, so I haven't been able to work on the truck. I'm assuming this is the part even though it's called something else;
File Type: jpg
Old May 29, 2016 | 02:40 PM
RalphP's Avatar
RalphP
If you want to pay that much, do .. .but RocKAuto has'em for (most expensive one!) under $24, and if you don't mind cheap, down to about $16 (!!!)
RwP
Old May 30, 2016 | 07:23 PM
David Dudemaine
So the needles move a little bit but not much. I double checked connection. Maybe it's the cluster? Gonna hafta wait until I get home to buy any replacement parts. I still think it's a short by the computer by one of the three terminals. Probably the bus one (whichever that one is)
Old May 31, 2016 | 06:41 PM
David Dudemaine
Ok. I might have found the culprit. I found a melted connector that comes fm under the coolant container but looks like it's comes from the PCM. It's got 4 wires in it
Old Jun 2, 2016 | 06:53 PM
Friar Tuck's Avatar
Friar Tuck
Thumbs up Shorted wiring?
Fantastic find! Tell us how you found it. Which wires?
Old Jun 2, 2016 | 06:58 PM
David Dudemaine
I saw this hanging down but I think it's a heated 02 sensor (upstream). Not sure what the smaller connection is though. I am thinking of doing the crankshaft position sensor and or cam shaft sensor
File Type: jpg
Old Jun 2, 2016 | 07:15 PM
Friar Tuck's Avatar
Friar Tuck
Is that white one for washer fluid sensor or pump? It looks like something's plugged into the black one. I'm trying to find a manual or schematic for the '97.
Old Jun 2, 2016 | 08:12 PM
Friar Tuck's Avatar
Friar Tuck
Can you tell what is plugged into the black plug? Looks like maybe a jumper plug or inline fuse. If you can see the wire colors, I think we can figure out what it is and where it goes.
Old Jun 2, 2016 | 08:54 PM
David Dudemaine
I can't right now but I know it's got 4 of them. I will let you know when it stops raining. I was thinking 02 sensor because it looked like one in a Haynes book I got
Old Jun 2, 2016 | 09:27 PM
Friar Tuck's Avatar
Friar Tuck
ok, stay dry!
