Engine Shudders after Overheating
Old Jul 14, 2016 | 11:20 AM
wihaltom's Avatar
wihaltom
Originally Posted by 98DAKAZ
why would you ever need to replace all your coils one or two maybe but all?
As I said dose not compute easy test would be move any suspect coils around to confirm they are bad
I made the mistake of putting some aftermarket coil packs on my engine a few years back so if I was going to change one or two, I would probably change them all back to Mopar parts.
I may do that anyway, now that I think about it.
The truck runs like a spotted-assed ape, but I would like to make it run just a little better.
I wish Accel made coil packs for the 4.7.
I've used their product on other engines and they really made a difference.
Old Jul 14, 2016 | 01:00 PM
98DAKAZ's Avatar
98DAKAZ
Ok makes sense
You should test for a blown head gasket and mark it off as a possibility
Dodgevity has been dealing with a very mild blown head gasket just recently he didn't think he had a blown gasket till he tested positive.
Old Jul 18, 2016 | 09:03 PM
Dodgevity's Avatar
Dodgevity
Yeah, I rented a chemical tester from Autozone and it failed. Happy to report though, that K&W block seal fixed the problem. I had to go against their instructions and run it in the cooling system for 500 miles.
