Best Plugs for 3.9L?
Old Jul 7, 2016 | 09:05 PM
Suzonda's Avatar
Suzonda
Default Best Plugs for 3.9L?
So I have a bit of a predicament. All my driving life I've ran 1st gen Dakotas and Dangah R***ahs since they're indestructible work trucks and I know what they like. Though a recent purchase of a '01 w/a 3.9L, 42RE, 2wd has stumped me. I run NGK Iridium IX in my '92, '93, and '96 with no issues. As soon as I put them in my '01 with the it pings, spits, and runs like crap. It HAD Champion 4071 "Truck Plugs" which are JUNK in anything. So Other than Champions what'd be the best plugs for my trash hauler?
Old Jul 8, 2016 | 04:44 PM
patchelect's Avatar
patchelect
My truck, which I purchased from new, is running the plugs it came with and having NO problems. Can't tell you what they are though, since I am of the school of "if it ain't broke, don't fix it". Change oil and filter when the clock or the odo are at the right time, check brakes and tires and all that good stuff, but plugs and wires haven't been touched. Not lots of miles on the truck, 65K, but no reason to mess with what works.
For my non truck vehicles I tend toward NGK plugs if that is any help.
As for our Iridium plugs, I've never read anything grand about them, but YMMV I guess.
Old Jul 18, 2016 | 08:26 AM
duke07's Avatar
duke07
You can't go wrong with NGK plugs. Bosch is another dependable brand.
Old Jul 26, 2016 | 05:58 PM
BigGreenRam's Avatar
BigGreenRam
Tune up at 30 grand on my 2000 dakota plugs cap button wires but it only has 37xxx on it. I run champion plugs that's is oe. Molar cap/ rotor 7mm wires mid price bout 50+/- bucks she runs great
Old Jul 27, 2016 | 07:15 PM
Toby Warford's Avatar
Toby Warford
ALWAYS use copper plugs in 3.9's, 5.2's and 5.9's. Anything else is plecebo, wasting your money and possible doing more harm then good in your engine.
Old Aug 1, 2016 | 02:02 AM
Suzonda's Avatar
Suzonda
To avoid IBTL I actually put NGK Iridium IXs in it an the thing runs mint. Popped a Borg Warner cap, MSD 8mm wires, and swapped the TB for a 5.7 and the thing will haul just about anything I throw at it... as long as the oil is full. It idles at around 800-950 but I figured better contact and adjusted timing fixed it.
Old Aug 4, 2016 | 01:24 AM
Paulbutler's Avatar
Paulbutler
Should have a emissions sticker under the hood. The copper champions are the ones I believe came with your truck when new. They have a .040 gap
Old Aug 4, 2016 | 06:38 AM
Toby Warford
Yup, rcy12c, same plugs as another magnum I had took, a 22hp Kohler magnum lawn mower.
Old Aug 9, 2016 | 11:41 PM
Suzonda's Avatar
Suzonda
It will NOT run Champions or Autolites. Tries to fight every chance to run right at every turn. Bosch is crap in it. It only seems to like NGK or Motorcraft. It's the same as putting Champions in a Jap bike. It WILL NOT RUN.
Old Aug 10, 2016 | 03:29 AM
Toby Warford
You're truck must be a real work of art. "Can't" have a glass pack on it or "the transmission won't shift right" and "can't" have OEM plugs.
