Overhead console
Old Jul 28, 2016 | 12:08 PM
John3475's Avatar
John3475
Default Overhead console
Is the wiring in place for the overhead console with compass temp mileage etc if I take down my basic one?
Old Jul 28, 2016 | 12:55 PM
00DakDan's Avatar
00DakDan
Section Moderator
I moved your post to a new thread John.
Likely no. It wasn't on my '00. You should have wiring for the dome light but you'd need to run wires for the temp sensor.
Old Jul 28, 2016 | 01:59 PM
John3475's Avatar
John3475
The compass prob just need spower I assume
Old Jul 28, 2016 | 03:16 PM
00DakDan's Avatar
00DakDan
Section Moderator
The compass yes but the thermometer will need to connect to the PCI bus in the vehicle. You can probably tap it at the OBD port. The temp data comes over the PCI bus via the HVAC controller.
I show 7 wires for the console vs. just 3 for the base lights.
You have power - 12 volts always hot. The outputs are switched to turn the lights on/off. 1 wire each to the courtesy lamp driver and to the interior lamp driver on the CTM.
You need to add: 12 volts switched, panel lights dimmer, a ground, and the PCI bus connection.
Old Jul 29, 2016 | 08:31 AM
John3475's Avatar
John3475
Default console
Yea, that sounds like greek to me, I appreciate the info though. I assume the wires are not there for a swap out then.
Old Aug 1, 2016 | 12:23 AM
Dakota~N~Camaro's Avatar
Dakota~N~Camaro
Wires are not there but it's simple as can be to add it. I yanked the harness out of the truck I pulled it from and just cut the wires near the kick panel.
I paid $10 for the console because it was broken, I removed the blank "clip" on my oem console and installed the computer display in my good console the ran the wires. Took no time at all.
Here is the video I watched to walk me through it.
