interior lighting issue
Old Aug 22, 2016 | 09:32 AM
somedaysoon's Avatar
somedaysoon
Default interior lighting issue
Hi everybody, new to the forum. So I'm redoing my interior, and I decided to get some leds for the inside lighting. When I was parking my truck last night I noticed that both the front and rear led were glowing a bit. So I moved a bulb around abit and they went off. Problem is none of them would come back on that way either. So I put it back the way it was (slightly glowing) and the switch worked fine. Funny thing is when I unplug the front dome or visa versa fixtures wouldn't glow and would work as it should. I don't know much about electrical. Is it one of the harnesses? Do I need a larger Fuze for led? Were is it located. Thanks for your opinions everybody
Ps it's a 2004 sport club 4x4 v6 5 speed
Old Aug 22, 2016 | 03:16 PM
Toby Warford's Avatar
Toby Warford
That's the nature of LEDs. O recommend to do some googling.
Old Aug 24, 2016 | 08:55 AM
Normal operation of LED bulbs as mentioned. It's called a trickle discharge, or "ghosting". Because LEDs take so little power to operate when they are left in a circuit, even if off, you can still have a small amount of power making them glow. I've heard canbus LED bulbs do no have this issue.
