Front shocks
Old Sep 6, 2016 | 11:07 AM
Daren Hanshew's Avatar
Daren Hanshew
Default Front shocks
Ok i purchased a 97 dakota 4wd it had been sitting for 3 years. I replaced the front end suspension over the weekend. The main bolt on the front shocks however broke off and i am wondering what the best way to get this bolt out is without damageing the threads?
Old Sep 6, 2016 | 11:40 AM
00DakDan's Avatar
00DakDan
Section Moderator
Probably some heat and a bolt extractor.
It's a common problem.
Old Sep 6, 2016 | 10:16 PM
burcs's Avatar
burcs
For the upper shock nut, a sawzall or cut-off wheel. Slide it under the bushing and go to town.
For the lower bolts, as previously stated, a bolt extractor is pretty much your only option.
Old Sep 7, 2016 | 08:04 AM
Daren Hanshew
Thanks for the info. uppers were no issues however it seems the lower bolts are gna be my nightmare both driver and passenger bolts broke off....had penetrating oil on passenger side for 2 days....awww well joys of working on your own truck lol
Old Sep 7, 2016 | 11:18 AM
burcs's Avatar
burcs
Another option is to replace the control arm. They're $70-80 new, and you could probably find them at a salvage yard much cheaper, though I'd put new bushings in if you go that route.
Old Sep 7, 2016 | 11:21 AM
Daren Hanshew
Ill keep that in mind if i cant get the bolt out
