you probably have water where it doesnt belong. let it dry out and if it doesnt get better than pull the cap and check for mositure in there. if there is, then dry it out and re-check it. if you do nothing and let it run and it runs better, then check your wires. you might have some bad wires causing a miss fire to the block.
Bingo...
was no seal at bottom od dist...
musta gotten wet...
was gonna replace with accel....ahead of schedule now that I know it can't be trusted...
thx
