98 Dakota Brakes - Advice
Old Dec 20, 2016 | 08:39 PM
magnethead's Avatar
magnethead
And seeing that you're in northern virginia- if your rear brake line behind the gas tank has not cracked open yet, just set aside a couple bucks a week and plan to replace it next summer, if not sooner. Very well known spot for road salt to collect and corrode the line.
Old Dec 20, 2016 | 09:27 PM
98DAKAZ's Avatar
98DAKAZ
Talking
A one person bleeder works great many videos available and its cheap buy some Silicone hose on ebay for the needed line about 3 feet of 4mm thats ID not OD 5mm may work but a loose fit.
ID= inside diameter
OD= outside diameter
http://www.ebay.com/itm/Silicone-Vacuum-Hose-3-4-5-6-8-10-12mm-High-Performance-Red-Blue-Black/252148512541?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D38530%26meid%3D38251540c82547a9a011767c485769c0%26pid%3D100011%26rk%3D2%26rkt%3D3%26sd%3D261191598660
