1997 2wd dodge dakota oil pan gasket
Old Dec 3, 2016 | 10:50 AM
2BALL's Avatar
2BALL
Default Oil pan gasket
I have a oil leak from the oil pan. it is leaking on one of the corners. the gasket is the original gasket. (19 years old)
Will I be able to change the gasket without completely removing the oil pan?
I need to lift the engine to take the oil pan off and I don't want to do that.
It looks like the pan will drop an inch or two without lifting the engine.
Do you think i will be able to change the oil pan gasket without removing the oil pan?
maybe I can use the liquid gasket in the leakey corner?
Anyone?
I feel like there is enough "stretch" to the gasket that I can replace it only dropping the pan an inch.
I have the same issue with a 1997 V8 Dakota. I can see the gasket is coming apart and is stringy on the corner of the oil pan (20-year-old gasket). The oil pan won't come out without doing the engine lift, but it looks like it will drop an inch and I wonder if I can replace the gasket without totally removing it. I have heard people on the internet say it could be done.
Old Jan 29, 2018 | 07:35 PM
2BALL's Avatar
2BALL
bumping this thread from a year ago. I still have this issue, very slight leak from 1 corner of the oil pan.
Old Jan 29, 2018 | 08:25 PM
Dodgevity's Avatar
Dodgevity
Drop the pan as far as it will let you. Clean the area with a toothbrush, dampened with brake cleaner, then a rag. Apply black Permatex RTV, hand tighten,wait an hour then torque.
