2000 Dodge Dakota 5-speed
Old Jan 24, 2018 | 09:14 AM
bnrhudsons's Avatar
bnrhudsons
Default 2000 Dodge Dakota 5-speed
My check engine light is on and the code reads a bad crankshaft position sensor. We removed the passenger side front tire and felt around behind the block and it wasn’t there. Does anyone have an idea where it might be or if there is even one there because some of the posts I read said the manuals don’t have one.
I’d appreciate any help.
Thanks,
Robin
Old Jan 24, 2018 | 09:23 AM
Moved to the correct section.
Old Jan 24, 2018 | 12:32 PM
93 ragtop's Avatar
93 ragtop
Here is a picture of a nv3500. the notched place is where the sensor sets. (I think!!)
Old Jan 24, 2018 | 08:37 PM
magnethead's Avatar
magnethead
It's mounted on the block behind the passenger head if you have a 3.9 or 5.2 5 speed. If you have a 4.7 5-speed then it is inside the block casting itself and a royal pain to R&R.
Old Jan 25, 2018 | 05:51 AM
93 ragtop's Avatar
93 ragtop
Magnethead, The NV3500 I posted above, is supposed to be out of a 2003-04? dakota with a 4.7 engine. Is the notch in the bellhousing for the sensor, or something else?
FWIW I purchased this transmission off of craigslist and used it in my 87 dakota. I dont have a crankshaft sensor......
Curiosity has me wondering what the notch was for.
Old Jan 25, 2018 | 01:23 PM
magnethead's Avatar
magnethead
I don't know if the 5 speed 4.7 kept the notch from the pushrod motors or not. But i know the 4.7 crank sensor is in the block and usually breaks off when removal is attempted.
Old Jan 29, 2018 | 07:00 PM
bnrhudsons's Avatar
bnrhudsons
Default 3.9l
Found out for sure I have the 3.9. When you say behind the passenger head what do you mean? I've come at it from above and can't find squat, and removed the front tire and wheel well cover to no avail. I just can't seem to find this thing and it's driving me crazy. The truck stalls randomly, doesn't always want to start, and the glare from the CEL is driving me nuts 😆 Thanks for the help so far and look forward to fixing this and putting it behind me
Old Jan 30, 2018 | 09:43 PM
magnethead's Avatar
magnethead
OK, so on the 3.9/5.2/5.9, you can't actually see the sensor without a dentists mirror or actually taking the tire off, even then you'll only see the bracket since the sensor is inside the bellhousing. It's mounted to the block itself, way down low. The bolts are 5/16 (1/2 inch wrench), bottom/outside one comes out easy, top/inside one is a complete PITA. This is the best photo I have showing it's location.
Well, apparently all the good photos have bad words in the randomly generated google link >.> So here's a couple short URL's
https://photos.app.goo.gl/NsYZREsmwHzT2lds2
https://photos.app.goo.gl/ij2I80h2Xrb4NelE2
https://photos.app.goo.gl/0RyKbBjEJB5gpT4j1
