Rear axle question:
Old Feb 2, 2017 | 03:32 PM
tonypilot7's Avatar
tonypilot7
Default Rear axle question:
I have an 02 2wd with 3.55 gears. I have found an '04 2wd with 3.92's for a decent price.
Both are the 8.25" and both have drum brakes..
Can I do a straight swap? or is there a difference between 02's to 03-04's?
Old Feb 2, 2017 | 04:15 PM
44dakota's Avatar
44dakota
97 to 04 should all interchange, 05 is when they went to 5 lug and some rear disc also.only issue i can think of is some are spring over and some are spring under,so check to see if the spring perches match with with your axle..
Old Feb 2, 2017 | 06:23 PM
magnethead's Avatar
magnethead
both being 2WD should be spring under, you should be fine with the swap
Old Feb 2, 2017 | 06:31 PM
tonypilot7's Avatar
tonypilot7
Sweet. Thanks
