Rear brake question
Old Feb 3, 2017 | 10:14 AM
hidden1's Avatar
hidden1
Default Rear brake question
If I need to replace literally everything on rear brake area plates and springs an all is there a way I can pull the entire assembly w or without hub out after disconnecting the lines an unbolting the main bolts holding it in ?.
I am pulling one off a dead truck an looking for a quick way to just get it off since I need many of the parts .
It's a 02 Dakota .
Thanks
Thanks
Old Feb 3, 2017 | 12:27 PM
98DAKAZ's Avatar
98DAKAZ
I don't think thats possible for one the parking brake cable connection unless you use bolt cutters for the cable.
Not to mention the little problem of an Axel in the way.
Old Feb 3, 2017 | 05:23 PM
magnethead's Avatar
magnethead
If you're pulling the whole backing place, have to open the diff, remove the C-clips, pull the axle, pull the parking brake cable.
Old Feb 4, 2017 | 01:12 AM
98DAKAZ's Avatar
98DAKAZ
New brake parts are very cheap
backing plate is not cheap $100 and up dealer only or used.
