01 dakota stuck in 4x4
Old Feb 16, 2017 | 06:51 AM
ray299's Avatar
ray299
Default 01 dakota stuck in 4x4
Hey all- I bought a truck that had a broken front drive shaft. I replaced it and it stuck in 4x4. I checked the fuse in the hood, it's good. what else would make it stick in 4x4? It's a turn switch with three options- 2wd, 4H and 4L... any way to test the switch? I want to drive it but not if it's going to be stuck in 4wd...
TIA
Old Feb 16, 2017 | 07:20 AM
ray299's Avatar
ray299
I found a thread that said go fwd and bwd and it solved the problem for a lot of people but I must have done that a dozen times and it's still in 4wd...
I also found a thread about a transfer case control module... this is in the left kick panel under the dash, correct? I hear it clicking...
Old Feb 16, 2017 | 10:56 AM
00DakDan's Avatar
00DakDan
Section Moderator
It could be the switch, the tccm, or the selector motor.
There should be a code stored but you'd likely need a DRB to read it.
Old Feb 16, 2017 | 11:03 AM
ray299's Avatar
ray299
I have a Snapon Modus and I see no codes... there are also no lights on the dash and if the 4x4 is supposed to light up.. it doesn't...
Old Feb 16, 2017 | 01:33 PM
00DakDan's Avatar
00DakDan
Section Moderator
There are two fuses in the junction block, by the door too.
Attached are the schematics.
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 16, 2017 | 07:59 PM
ray299's Avatar
ray299
thanks for the schematics. They'll come in handy if it's not a simple fuse..
Old Feb 17, 2017 | 10:47 AM
ray299's Avatar
ray299
ok, fuses in fuse panel are good, switch tests good, but i cant find the color coded wires leading to the module... I unplugged all three connectors and none of the colors matches the diagram from the switch. I'm going to have to do some more research but I hear clicking in the module... maybe it's trying to run something that isn't working?
