power gains
Old Feb 23, 2017 | 07:14 AM
Jeff Wheeler's Avatar
Jeff Wheeler
Good to hear can't can't wait try it out. There is a problem I'm having with removing the fan. I recently bought a new fan clutch and went to take the old one off and the nut is nearly impossible to remove. I've tried everything and now I may have to take it somewhere
Old Feb 23, 2017 | 07:43 AM
hemifever's Avatar
hemifever
SPONSOR
it should remove opposite of left/loose. Should be right/loose
Old Feb 23, 2017 | 07:54 AM
Jeff Wheeler
That's the direction I've tried to go and it still won't break lose. To make matters worse the pulley keeps turning
Old Feb 23, 2017 | 01:54 PM
hemifever's Avatar
hemifever
SPONSOR
yes its hard to keep the pulley from moving. I use a crow bar and wedge it in against the pulley and engine block to keep it from rotating
Old Feb 23, 2017 | 03:07 PM
Dodgevity's Avatar
Dodgevity
Two words... Impact wrench.
Old Feb 23, 2017 | 03:13 PM
Jeff Wheeler
OK I'll give it another try after work and let you know
Old Feb 23, 2017 | 03:46 PM
Originally Posted by Jeff Wheeler
OK so I just ordered an electric fan. What different does this make? Will it be noticeable?
Not enough to hardly notice. But, combined with a tune you will pickup a little pep.
Old Feb 23, 2017 | 06:21 PM
magnethead's Avatar
magnethead
The fan on mine was normal thread. I took a spare belt and vise-gripped it into a band clamp, used a 12" crescent tightened onto the nut, and swung at it with a sledge hammer.
