2003 Dakota window switches don't work.
Old Feb 27, 2017 | 08:52 PM
Harrison Grant's Avatar
Harrison Grant
Default 2003 Dakota window switches don't work.
Hi everyone, I'm new here, and I just bought my first vehicle- A 2003 Dodge Dakota Crew Cab with 4WD. Ever since I got it, however, the power windows will not work from the passenger side front and rear windows, or the driver's side rear window. They will only work from the master switch on the driver's door, and the window lock button is not on. I have no idea what to do. Any help would be much appreciated.
Old Feb 28, 2017 | 08:05 AM
Pull the switches out and clean the contacts. Check and verify you have voltage at the switches. Test the motors and make sure they are working. Check all the fuses.
Old Feb 28, 2017 | 09:50 AM
patchelect's Avatar
patchelect
There is a childproof switch on the drivers door that is known to go bad. Somewhere on this site is the procedure to jump out the function. I did it on my '01 and it worked great. Originally the problem was intermittent but it became all the time so I searched and found the fix. Cleaning contacts "might" be a fix but from the thread I had seen the childproof switch is the culprit. It is highly unlikely that you have three bad motors. And you won't find voltage if the switch is the problem because its purpose is to kill the power to all the switches but the drivers side.
Old Feb 28, 2017 | 12:24 PM
Dodgevity's Avatar
Dodgevity
I've got the same issue... same truck, sans the 4WD. The links are in my thread. Just haven't tried to fix it yet cause work has me so busy. https://dodgeforum.com/forum/2nd-gen...r-windows.html
