ABS Speed Sensors
Hey Guys - new to the forum but I have a question for you: Is it possible to have front ABS speed sensors without having ABS in the front?
I recently bought my truck (98 sport 5.2) and both the ABS and brake light are on constantly, and the speedo doesn't kick on until 20mph or slightly after. I did some reading on here and everything was pointing me to replacing the rear sensor...I had a mechanic checking out the truck though for another issue (EVAP) and he told me his reader was saying it was the front left ABS speed sensor. Fast-forward a few weeks and I have purchased a front ABS speed sensor but when I jacked up the truck took off the wheel and took off the brake caliper I couldn't find it anywhere. Anyways so that's the back story, I also have my build sheet courtesy of FCA, but from everything I see on there I only have ABS in the rear (please correct me if I'm wrong). If it's not possible, did the mechanic just read the code wrong?
Any help would be appreciated!
here's my trucks build sheet:
*M5 Cloth High-Back Bucket Seats
-C3 Mist Gray
ADAP Light Group
ADHP Heavy Duty Electrical Group
ADJ Heavy Duty Service Group
ADL Skid Plate Group
AGGP Sport Group
AJKP Deluxe Convenience Group
AJP Power Convenience Group
APAS Monotone Paint
A31P 5.2L Eng(ELF)/4Spd A/T 44RE(DGW)
BAZP 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKPP 10x2.5 Rear Drum Brakes
CADP High Back Bucket Seats
CBVP Cloth Door Trim Panel w/Map Pocket
CCAS Rear Fold Under Seat Storage
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CJTS Seat Track Cover
CKES Front Seat Area Carpet
CSRS Passenger Assist Handle
CUCP Floor Console
DGB All 4-Speed Automatic Transmissions
DGWS 4-Spd. Automatic 4RE Transmission
DHAP Lock-Up Torque Converter
DHKP Shift-on-the-Fly,231HD Transfer Case
DJLS 175MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
ELF 5.2L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GFDP Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNDP Driver Side Sun Visor
GNEP Passenger Side Sun Visor w/Mirror
GT4 Power 6 X 9 Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXRP Keyless Entry
HAAP Air Conditioning
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJP 12V Power Outlet Mounted in IP
JPAP Power Windows
JPBP Power Locks
KNSS RADTIANT SILVER MET. C/C - BADGE
KRSS RADIANT SILVER MET. C/C - BADGE - DO
KSSP RADIANT SILVER MET. - BADGE
KTSS RADAINT SILVER MET. C/C - BADGE
K2CP EXTERIOR COMPONENT COLOR
LAAP Seat Belt Alert-3rd Row
LBBP Courtesy Lamps
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LDAP Underhood Lamp
LMBS Halogen Headlamps
LNJP Fog Lamps
LPEP Cargo Lamp
LPSS CHMSL Lamp
MBAS Body Color/Black Front Fascia
MBV Painted Rear Bumper
MDAP Front License Plate Bracket
MFNP Grille-Body Color
MHAS Black Windshield Moldings
MLAP Body Color Fascias
NAE California Emissions
NBKS EVAP Control System
NFBP 22 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PB3 Intense Blue Pearl Coat
QB3S Intense Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RAZ AM/FM Cassette Compact Disc Radio
RCKP Infinity Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHCP Rear Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TUTP 31X10.5R15 OWL All Season Tires
TZAP Goodyear Brand Tires
WJ9P 15X8.0 Aluminum Wheels
XBSS Pickup Box
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XEUP Front Suspension Skid Plate
YAAS Build To U.S. Mkt. Specifications
-C3 Mist Gray
ADAP Light Group
AGGP Sport Group
APAS Monotone Paint
CUCP Floor Console
EAAC All Engines
GXRP Keyless Entry
JJAS Cigar Lighter
JPAP Power Windows
JPBP Power Locks
LBBP Courtesy Lamps
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LDAP Underhood Lamp
LNJP Fog Lamps
LPEP Cargo Lamp
LPSS CHMSL Lamp
NHMP Speed Control
XBSS Pickup Box
