loose shifter part needed
Old Jun 10, 2017 | 10:15 AM
93 ragtop's Avatar
93 ragtop
Default loose shifter part needed
I have a NV3500 out of a 2002-2003 dakota. The shifter is loose and after taking it apart, there are 2 bushings missing. In the link attached, post 8 there is a picture of the 2 small, yellow bushings. Does anyone know of a source for them? I thought about going to a hardware store and seeing if I could find something close and maybe cut it down to fit, but would rather just buy new if available. Thanks for your help.
https://dodgeforum.com/forum/2nd-gen...placement.html
https://cimg0.ibsrv.net/gimg/dodgefo...296975f17e.jpg
Old Jun 11, 2017 | 08:13 AM
98DAKAZ's Avatar
98DAKAZ
I don't think those are available a new shifter is your only choice good luck with that.
Old Jun 12, 2017 | 06:23 AM
93 ragtop's Avatar
93 ragtop
Thanks for your reply. FWIW I purchased this transmission used to put in my 87 dakota. I believe whoever pulled the transmission has lost these bushings. For now, I am going to try and make some from nylon. Then if everything else works ok with the trans, I will look for a new shifter.
Old Jun 12, 2017 | 10:37 AM
98DAKAZ's Avatar
98DAKAZ
Smile
You could try a hard wood like Oak whatever you use it needs to be tuff to take the beating it gets.
Old Jun 14, 2017 | 08:40 AM
93 ragtop's Avatar
93 ragtop
[QUOTE=98DAKAZ;3346438]You could try a hard wood like Oak whatever you use it needs to be tuff to take the beating it gets.[/QUOTE]
I went to home depot and found this. http://www.homedepot.com/s/595%2520383?NCNI-5
The picture is a little deceiving. That is actually 2 spacers up against each other.
I drilled it out with a 1/4 bit, and that fit tight on the shifter. I then slightly ground the 2 sides so it would go in the housing. Then I had to slightly grind the top so it would pivot, slightly side to side.
I think it will work pretty well. But I have not got to drive it yet.
Once I do I will post some pictures
