Replaced the O2 sensor but still have code p0155
Old Jun 17, 2017 | 07:55 PM
graeaglecrawler's Avatar
graeaglecrawler
Default Replaced the O2 sensor but still have code p0155
Is there a certain number of miles before the code clears? My code reader won't clear it. I replaced the passenger side upstream sensor.
Old Jun 17, 2017 | 10:18 PM
Skreelink's Avatar
Skreelink
On my dakota, I cannot clear codes unless I turn the truck off, pull the key out, back in, then turn it to the on position without starting the truck. Then you should be able to clear the codes, otherwise, pull the negative battery terminal for a few minutes.
Old Jun 18, 2017 | 12:18 AM
graeaglecrawler
Thank-you, how did you figure that out? I have been trying to cycle the key and disconnecting the negative post.
Old Jun 18, 2017 | 10:35 AM
graeaglecrawler
Thanks, that worked I was trying to clear it with the truck idling.
Old Jun 18, 2017 | 02:06 PM
Skreelink's Avatar
Skreelink
Glad it worked for you.
