Dreaded Spark Plug Heat Shields
Old Jul 23, 2017 | 10:27 PM
honkbert's Avatar
honkbert
Angry Dreaded Spark Plug Heat Shields
I have browsed other heat shield removal threads on here and there wasn't a singular solution, it appeared.
I have a 2000 Dakota 2WD 3.9L V6. I'm just trying to change the spark plugs and I've already broken off the ceramic sections on two of them. It is not going well. These stupid heat shields are impossible, so I saw that some people suggested removing them.
I've tried the twisting, the pulling, the hammering, the prying, PB blaster soak for a couple days. NOTHING. I'm giving it all my elbow grease and it seems just so rusted in there.
This all, by the way, is just one attempt on cylinder #3, which is the easiest to access by hand and tool. I have absolutely no idea how I'm suppose to wrestle a pig in the tight quarters of the other spark plugs.
My last hope is soaking the heat shields in a 50/50 mix of acetone and ATF fluid. Any other ideas?
Old Jul 23, 2017 | 11:36 PM
magnethead's Avatar
magnethead
Mine just came out with a pair of pliers (rust-free truck in TX). You being in michigan will definitely have an uphill battle. The heat shields get rusted in, and they also collect moisture, which then rusts the plugs in.
I popped mine out with the plugs still in (to prevent crap into the cylinder), blew the recess out with compressed air, then tapped it back in and changed the plug.
Old Oct 17, 2017 | 11:39 PM
honkbert's Avatar
honkbert
Default Update: worthless trip anyways
Yeah a few of those heat shields were in there. I had to hit a few of them with 15 minutes of heat and then chisel them out.
But it was all for not because one of the spark plugs left it's threads behind and I had to pull the effin' head anyways. This has been a learning experience.
Old Oct 24, 2017 | 02:04 PM
98DAKAZ's Avatar
98DAKAZ
Yea if you live in a bad rust belt change your sparkplugs every 3 years or you may never get them out especially with cast iron heads.
