Need help 5.9l magnum multiple misfire
Old Jul 28, 2017 | 07:30 PM
2001dakotaRT's Avatar
2001dakotaRT
Default Need help 5.9l magnum multiple misfire
So it all started when i went for a bid ride, the truck ran fine and then on the way back home i started to loose cylinders.
The only cylinders that get hot are 1,3,4,7
#5 get warm and 2,4,6,8 are cold
and she backfires through the intake.
I plugged my OBD2 code reader up to it and the only code i get is p0031
The truck has fuel pressure(40psi)
all cylinders have spark/fuel going to them
all cylinders have pressure (~150psi),
I've change the distributor cap, changed cam positioning sensor and i also checked the timing and it's dead on.
tomorrow i will change the crank positioning sensor
2001 Dakota R/T 5.9l
Thanks in advance - Kyle
Old Jul 28, 2017 | 08:24 PM
magnethead's Avatar
magnethead
Are the plugs wet? How do you know the fuel injectors are firing?
Timing cannot by adjusted on our trucks, the cam sensor within the distributor has to be synced to within +/- 5 degrees of the cam sensor ("Fuel Sync").
Have you checked for bad catalytic converter?
Old Jul 29, 2017 | 09:00 AM
00DakDan's Avatar
00DakDan
Section Moderator
40 psi? Your fuel pressure is low.
Spec is 49.2 +/- 5.
Old Jul 29, 2017 | 10:22 AM
2001dakotaRT
plugs are wet, and im running no cats
Old Jul 29, 2017 | 10:34 AM
2001dakotaRT
Spec is 49.2 +/- 5.
I will look into a new fuel pump
Old Jul 29, 2017 | 12:23 PM
magnethead's Avatar
magnethead
You tested for spark using a screwdriver or holding a spark plug against a ground, yes?
If so, the only way the plugs can be wet in presence of spark is that the fuel sync is off by a mile.
Old Jul 29, 2017 | 12:31 PM
00DakDan's Avatar
00DakDan
Section Moderator
Agree with Magnethead on the fuel sync.
Did you turn the distributor at all?
Old Jul 29, 2017 | 01:40 PM
2001dakotaRT
Angry
Yes i tested the spark against the ground it's nice and blue.
No i did not turn the distributor at all, i did test the fuel pressure once again and at idle the gauge is jumping like crazy from 40-50psi.
Im gonna replace the fuel pump today and see what happens
Old Jul 29, 2017 | 02:42 PM
44dakota's Avatar
44dakota
p0031 is a bad o2 sensor bank 1, this is likely your problem and not the fuel pump, even though the fuel pump probably does need replaced, its not going to cause wet plugs like an o2 sensor would..
Old Jul 29, 2017 | 07:37 PM
2001dakotaRT
I jacked the truck up this morning and saw a O2 sensor was unplugged, so thats ruled out
Spec is 49.2 +/- 5.
I got a new fuel pump and installed it, i have a lot more fuel pressure now, but still down a few cylinders :/
