New to this forum
Old Jul 31, 2017 | 02:34 PM
Chache''s Avatar
Chache'
Default New to this forum
Hi all,
I'm a 72 year old kid. Living on Soc. Sec.
I don't feel like I'm 72 except for the joints...!
Three years ago, I bought an almost ready for the scrap heap 2000 Dakota 3.9L 2 dr club cab,
and have been slowly bringing it back to " good looking..
Some of the resto projects have included:
All new tires, new brake discs, new pads, grease job, replaced the water pump, new Battery, Flush and fill the Cooling system, recharge the A/C, replaced Plugs and wires, new stereo system, new Ext Rear View mirrors ( larger ones), a repaint,
new button tufted headliner, and a Tonnau cover for the bed. New Headlight assemblies with LED day- lights controlled by a roof panel from a 93 Bonneville, with its own individual interior lighting.
Previous owner ran it into the ground.... and did no maint. and the clearcoat was doing its thing...Peeling!
Roof was rusted, and I ground that away and filled the deeper spots to level. Repaint, is Rustoleum's "Kelly Green" enamel, with a hardener. It is doing well under this Southern Texas heat and Sun.
The 5 spd std. trans has a tendancy to pop out of gear in 1st and 3rd every once in a while, but I can live with that for now.
Two years ago, I had a problem where the Voltmeter would suddenly register +20 volts.... after driving for 10 - 15 minutes.. turned out to be a faulty ECU. Replaced that, and its been good to me ever since.. except for now, when it registers absolutely no charging at all after running for 5 - 10 minutes. I have a second voltmeter reading only the battery voltage, and that concurs with the dash meter.
If I shut down the ignition, and restart, it charges again for a few minutes, and stops charging again.
So that's where I am now.
Looking to get confirmation that I need to replace (again) the ECU.
So what do you all think??
Thanks in advance.
Chache'
File Type: jpg
File Type: jpeg
Old Jul 31, 2017 | 03:29 PM
Welcome to the forum. I moved your post to the correct area. I have no idea what link you were trying to paste in your post, but it loaded up the whole page with gibberish, so I removed it. Maybe try it again if it is relevant.
Old Aug 1, 2017 | 06:45 PM
Chache''s Avatar
Chache'
Default Charging issue
Thank You!
No link being pasted by me, just the two pics, which came thru.
Hopefully there's someone that can give me a bit of advice on the latest charging issue...
Now, it registers absolutely no charging at all after running for 5 - 10 minutes. I have a second voltmeter reading only the battery voltage, and that concurs with the dash meter.
The battery now won't crank the engine...
That's where I am now.
Thanks again.
Chache'
