03 Dakota trans issue
Old Aug 21, 2017 | 07:26 PM
Zach m123's Avatar
Zach m123
Default 03 Dakota trans issue
hey my 03 Dakota won't come out of limp mode and I can't tell if I'm in reverse or drive cause prnd all has a box around it has new speed sensors new oil pressure sensor and new solenoid pack and still in limp mode it has codes p0700 p0846 p0871 p0988 p0750 does anyone know what this is thanks
Old Aug 21, 2017 | 08:57 PM
Skreelink's Avatar
Skreelink
P0700: Transmission Control System Malfunction
P0846: Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance
P0871: Transmission Fluid Pressure Sensor/Switch C Circuit Range/Performance
P0988: Transmission Fluid Pressure Sensor / Switch E Circuit Range Performance
P0750: Shift Solenoid 'A' Malfunction
I would doublecheck your wiring harness, since you said you changed the pressure sensor and solenoid pack, it seems to not be reading them. You remembered to reset the PCM also I presume?
Clean the wire harness, make sure your connections are good (if you spliced as well), dielectric grease, etc. Did you do a Fluid/filter change to ensure the new sensors didn't immediately get clogged?
Old Aug 23, 2017 | 07:01 PM
Zach m123's Avatar
Zach m123
I just re checked everything it's all good is there anyway to test the trans oil pressure sensor thanks
