Hops rpms and dies, only when sitting. Out of ideas
Old Aug 26, 2017 | 07:17 PM
Brenton.b's Avatar
Brenton.b
Default Hops rpms and dies, only when sitting. Out of ideas
So I'm new to the forum, and am completely stumped on this truck. Never been a dodge fan so never really worked on them. I bought a 97 dakota 5.2, and it starts and drives fine, but once it's warmed up it'll hop rpms and try to stall when sitting in gear at stoplights or stop signs. It's even worse in reverse, it usually dies trying to back into the parking spot at work. It'll make some unusual pinging noises when hitting the gas after it's warmed up, and will drive fine with no service engine for a few weeks then throw ses for all cylinder misfire, unplug the computer and good for another few weeks. So far I've changed the spark plugs, wires, coil pack, iac sensor, map sensor, tps, cleaned the throttle body, changed intake and intake plenum gaskets, new fuel injector O rings, new air filter, new throttle body and air hat gasket, changed coolant and thermostat. So I'm out of ideas, maybe a bad pcm? I just changed all intake gaskets and haven't had an ses since but it still hops rpms, tries to die when sitting in gear and the pinging noises, any ideas?
Old Aug 26, 2017 | 08:02 PM
magnethead's Avatar
magnethead
I don't see crank sensor listed on that list. I know that when mine started acting up, it was doing the same thing. New sensor fixed it.
Old Aug 26, 2017 | 08:10 PM
Brenton.b's Avatar
Brenton.b
okay cool thank you, I will try that next. So a bad crank sensor won't throw a service engine? And would it cause the strange pinging noise as well?
Old Aug 27, 2017 | 02:09 AM
magnethead's Avatar
magnethead
When the sensor fails, it throws misfire codes rather than a code for the sensor itself (The PCM doesn't know the sensor is bad). The sound you are hearing may be the sensor getting beat to death by the tone ring or starter ring gear.
Old Aug 27, 2017 | 03:40 AM
Brenton.b's Avatar
Brenton.b
Okay, cool. Thank you very much. Definitely going to buy one soon. I was getting ready to give up on the truck haha.
Old Aug 29, 2017 | 02:54 PM
tonypilot7's Avatar
tonypilot7
Another item to check would be the O2 sensors and your fuel trims.
If the problem only happens in closed loop (only when warmed up) that points me towards the O2 sensors or something else in the closed loop operation. Throw a scanner on it that will give you live data and watch how your O2's are acting.
Here is a good video on how fuel trims can help diagnose a problem:
Old Aug 29, 2017 | 03:20 PM
Brenton.b's Avatar
Brenton.b
https://youtu.be/5WnM_NsOtd8
I will check this as well. I know I just changed the front 02 as it was throwing a code but haven't had a code for it thrown since. But I will check, thank you
Old Sep 2, 2017 | 04:22 PM
Brenton.b's Avatar
Brenton.b
So got around to changing the crank position sensor today, and it was idling hard as hell and kept shutting off, so I'm taking a break, clearing the computer and trying again, I double checked everything and didn't see anything I knocked loose and checked connection on the sensor so guess I'll see in a little while
