AWD spare tire question?
Old Aug 29, 2017 | 12:02 PM
Th3ory's Avatar
Th3ory
Default AWD spare tire question?
I have a 2001 Dakota awd 4.7.
The tires I have on the truck now are a 265/75/r16, all new. However when I bought the truck it had no spare. I called the local pick and pull and gave them the year of my truck and they said the had a 15x6 spare that they would have shipped to me for $45. I'm going to take the spare wheel to my local tire shop and have then match a close tire size to it. However after looking into spares for the 2001 Dakotas, I seen the 2001 Dakotas sometimes came with a 16x7 spare wheel?
The question I have is, will a 15x6 work with the AWD system. It does not match my stock wheels size. If my truck was 2wd or 4wd I wouldn't worry, however its the AWD and I need the tires all to match. Can I get by with that size spare wheel if I'm in a pinch. I do a lot of hunting deep into warehouse land, sometimes 30-50 miles in. If I needed to throw that spare on, with a close tire size, should I be fine to limp back to town on the AWD system without damaging the t-case?
Old Aug 29, 2017 | 12:05 PM
I would keep looking for the correct wheel for your truck. With an AWD system, you REALLY want all four tires as close to the same size as possible.
Old Aug 29, 2017 | 06:58 PM
magnethead's Avatar
magnethead
Dakotas used a full size spare. Get the matching 16x7 factory wheel like you already have.
Old Aug 29, 2017 | 10:04 PM
primem's Avatar
primem
the spare size should be listed in the tire placard.
with awd I prefer a full size rim that is match to the other rims... i do a 5 tire rotation....then if one tire gets damaged and is not repairable...you dont have to buy 4 new tires.
Old Aug 30, 2017 | 02:37 PM
Th3ory's Avatar
Th3ory
Thanks guys! After looking awhile longer, I found a full size 16x7 spare wheel at a local pick-n-pull. Took a second for the parts guy to realize they made a full size spare, but we found one
Old Aug 30, 2017 | 06:50 PM
magnethead's Avatar
magnethead
the 16" wheel was an option. The base model had the 15's, RT's have 17's. All 3 are considered full size spares, but the difference is which size was OE for that particular VIN.
