Throttle whine
Old Sep 8, 2017 | 02:03 PM
Raptoor4561's Avatar
Raptoor4561
Question Throttle whine
hi guys and gals, i have an 04 dakota with a 3.7l v6 in it, and i have a strange problem that i dont know how to diagnose. i have an a&P license to work on aircraft and have a pretty good knowledge of mechanical means, but ive never experinced this. the throttle will whine whenever i am at 20% throttle. this is a continuos whine at all speeds and gears, and im completely confused because it is a physical throttle, not drive by wire. any ideas? thanks in advance
Rap
Old Sep 8, 2017 | 03:01 PM
I assume you mean the throttle body? Or the throttle pedal?
Old Sep 10, 2017 | 06:17 PM
magnethead's Avatar
magnethead
probably just the air rushing by the throttle blades
Old Sep 11, 2017 | 08:51 AM
Raptoor4561
im honestly not sure, it only does it under load so i cant really test whether its the tb or the pedal, im guessing the pedal though, because its loud and clear inside the cab, and i have a very loud truck. a supper 44 that outlets before the tire and a short ram intake combine to make a lot of noise, but the driver can hear it very clearly, passenger cannot unless at low speeds. it mind boggling
Old Sep 11, 2017 | 01:38 PM
magnethead's Avatar
magnethead
The pedal can't really whine since it's not a constantly moving part. It could be some sort of harmonic, but it sounds more like a driver side exhaust leak, or air rushing through the TB. IAC will usually whistle, but it should be closed off idle.
Old Sep 11, 2017 | 04:21 PM
Raptoor4561
ill use a camera and try to pinpoint it, thanks!
