2003 Dakota top transmission bolts...
Old Sep 25, 2017 | 12:32 PM
pyrdog's Avatar
pyrdog
Default 2003 Dakota top transmission bolts...
I have 2003 Dakota 4x4 Automatic, I think it's 42RE but not sure, 3.9 V6 Standard Cab .... I need to replace the transmission... not sure of the best way to remove the top bell housing bolts... as it sits before doing anything I cannot get to them... Should I lower the trans to access under the truck? Or should I raise trans and access from top under hood? Any help would be very much appreciated!
Old Sep 25, 2017 | 01:27 PM
Since you are pulling the trans, I would drain the trans, drop the rear, and get the bolts from underneath.
Old Sep 25, 2017 | 05:54 PM
magnethead's Avatar
magnethead
I used a 24" extension, a center wobbly, a 12" extension, and an air ratchet.
Old Sep 25, 2017 | 08:03 PM
pyrdog's Avatar
pyrdog
Thanks you guys! So it is def doable from underneath? Thanks so much!
Old Oct 14, 2017 | 05:40 PM
pyrdog's Avatar
pyrdog
Well everything went together great but now it's making a taping and growling noise and when I try to drive the motor seems to labor a bit and growls! Any suggestions? It's a used trans from salvage yard! Thanks!
Old Oct 14, 2017 | 10:12 PM
magnethead's Avatar
magnethead
tapping would be converter bolts. Growling sounds like you got a POS used transmission.
