How to replace parking brake lever handle
Old Oct 21, 2017 | 01:23 AM
curiousv's Avatar
curiousv
Question How to replace parking brake lever handle
Mine is broke
2002 Dakota sxt..
I believe I have to remove driver side outboard end of the instrument panel correct?
if not how do I remove it?
Old Oct 22, 2017 | 07:13 PM
magnethead's Avatar
magnethead
The release handle, yes?
Remove three T-15/T-20ish torx bolts holding the plastic lower trim around the OBDII port. Make sure the trim is loose. Pull the release handle down, the metal rod pulls out towards the drivers door.
With alot of force, pull the trim panel back towards the driver's seat. There are 3 VERY strong clips around the steering column that hold the panel.
Old Oct 23, 2017 | 12:20 AM
curiousv's Avatar
curiousv
Thanks..I fixed..it thanks for your advice...
