adding a supercharger, should i upgrade stock pistons as well?
Old Nov 10, 2017 | 05:56 PM
Jon RT Lawrenz's Avatar
Jon RT Lawrenz
Default adding a supercharger, should i upgrade stock pistons as well?
first off i have searched for this kind of question, so...
im rebuilding a 5.9 and im at the point of do i need to upgrade the pistons or can i get away with using the stock ones. the goal is to get around 500 hp reliably.
thanks!
Old Nov 10, 2017 | 06:12 PM
Lower compression forged pistons. Anything else won't last. Stock compression is north of 9:1.... you don't want that for forced induction. (or, limit boost to 5-7 PSI.... and still use better pistons.)
Old Nov 10, 2017 | 09:00 PM
magnethead's Avatar
magnethead
Oh contrere. Flyin Ryan has several guys pushing 450+ on SBE with boost. Devin Lewis is making 10 pounds plus a 225 shot on a high mileage bottom end for the last 2 years. It just takes the right tuner to make it last. But generally, forged bottom end is proper....that's the route I am going. Ryan himself is currently putting a D1SC on his stock everything truck and setting up for 14 pounds at redline.
Old Nov 10, 2017 | 09:05 PM
magnethead's Avatar
magnethead
Also, MAJOR warning if you decide to do it the right way instead of the cheap way: Do not use any of the Hughes kits. There are a number of people having bearing failures around 500 miles in. Order a kit directly from SCAT with a forged crank. The Hughes kits use SCAT Cast cranks. The SCAT forged internally balanced kits are $2200 for either 365 or 408 inches.
